2008 super v8 shift issue
Old Sep 8, 2024 | 07:49 PM
mwapc's Avatar
Default 2008 super v8 shift issue
Odd coincidence as car is otherwise bullet proof
same day front left tire hit a significant pothole, the shifter would not release from park
Bolts on cable to transmission ( 2 ) are tight and accounted for underneath
Removed console cover to allow for manual override from park to reverse; getting to drive from reverse is recognized but does not engage forward motion unless you apply stronger pressure on shift lever to from R to D and then it engages forward motion
again bolts underneath intact and tight
Changed fuse F33 for jgate
is there a DIY I have not yet figured out ? no loose wiring connections that i can see at brake pedal under the dash
i was going to bring to transmission shop ( indiependent ) though i think not mechanical issue with transmission but rather electronic issue
pothole thump was pretty good....
anyone know any good jag independent shops south of Boston ; i am in 02043
Old Sep 8, 2024 | 09:26 PM
h2o2steam's Avatar
Double check you haven't tripped the inertia switch on the LHS A pillar.
Old Sep 9, 2024 | 09:31 AM
mwapc's Avatar
Mark
Thank you
I will try that today and let you know
appreciate the advice
Mark
Old Sep 9, 2024 | 05:05 PM
meirion1's Avatar
Mine does it on and off and I think it's the brake switch
In fact I have a spare and went to replace it but it seemed to cure itself
I think there are two colours green or blue-need to do some research on that
The switch is on the brake pedal
https://www.ebay.com.au/itm/19645266...BoCGMAQAvD_BwE
Old Sep 10, 2024 | 03:28 PM
Thomas-S.'s Avatar
Originally Posted by mwapc
Mark
Thank you
Mark
I believe that if the inertia switch has been trigggered, the engine will not start at all, which is not the case here. So I donot think that it is the inertia switch, but rather a problem with the electric block that the shifter has to avoid putting the car into drive from the park position without pressing the brake pedal.
Best regards,
Thomas
Old Sep 13, 2024 | 03:54 PM
mwapc's Avatar
Thanks all for input
code is faulting as follows:
U0103 Lost Communication with Gear Shift Control Module A
I have googled what exactly that is and what appears is entire unit as shown below
anyone know if this item is technically the Gear shift Control Module A ( was hoping the "A" designates a component of below vs the entirety -
GEARSHIFT SHIFT MODULE ASSEMBLY - C2C36038
Thumbnail Filmstrip of GEARSHIFT SHIFT MODULE ASSEMBLY - C2C36038 Images
Purchase GEARSHIFT SHIFT MODULE ASSEMBLY - C2C36038
Not Yet Rated | Write the First Review
Fits: Jaguar 2004-2009 XJ8 XJR
Part Number: C2C36038
List Price: Our Price: $1,194.47
Old Sep 13, 2024 | 04:32 PM
mwapc's Avatar
along the lines of above; does anyone have an installation guide on the replacement of the above part into the car
in the event i need to buy one i believe there is a connection to be made to the right side know as shown in picture; just want to be sure i properly install if the outgoing unit is not properly connected
Old Sep 16, 2024 | 11:24 AM
OldKarz's Avatar
Do you hear the switch activate when you move the lever from park to the right? Also would suspect connector issue rather than module. Did anyone ever spill a drink on the shifter.
Old Sep 16, 2024 | 12:24 PM
mwapc's Avatar
OldKarz
When moving the shift from park slight left to attempt to shift it beeps the customary beeps ; i can also see a pin from the shift mechanism below engaging with the white plastic - will try to upload photo
no liquid at all near the shifter area
Thanks for weighing in
Old Sep 16, 2024 | 09:33 PM
OldKarz's Avatar
Another thought: loosen transmission cable mount and re-tighten after moving to Drive then back to Park.
Position Sensor Monitoring
The TCM can identify errors with the position switch located within the transmission. If an
unrecognized position code is read by the TCM a plausibility fault will be logged. (A code is checked
between positions).
The position switch outputs a 4-bit code to the TCM, the bits being labelled L1-L4. For the
transmission, the following codes are used to identify the selector position.
Only for the automatic side of the J-GATE P,R,N,D
Selector position switch code
Position Code
L1 L2 L3 L4
Park 0 0 1 0
Reverse 0 0 0 1
Neutral 0 1 0 0
Drive 1 1 1 0
Old Sep 24, 2024 | 09:19 PM
mwapc's Avatar
new gear shift module a received today
i have console off and module revealed ; does anyone have guidance as to getting module out with cables removed and reconnected
cannot find that guidance on forums or in the manuals accessible
thanks
Robsovereign3.0
Jan 23, 2024 11:52 PM
Cneukum
Jun 6, 2022 10:09 AM
TomP
Nov 8, 2021 06:20 PM
thegreenjaguar
May 26, 2017 09:12 AM
prodigy215
19
Sep 10, 2015 12:37 PM
