2008 XJ Coolant Change burp button?
Old Oct 19, 2019 | 10:51 AM
steveg44's Avatar
Default 2008 XJ Coolant Change burp button?
Is there a way to burp it when doing a coolant change. It just wont take it all unless it sits over night practically
Old Oct 19, 2019 | 03:53 PM
meirion1's Avatar
I believe that if you park it on an incline or jack up the front end it helps
to release air from the cooling system.
Old Oct 19, 2019 | 04:06 PM
abonano's Avatar
Jack up front passenger end. Heat on full blast. Takes a few cycles to fully bleed. The hacking of the passenger side is for the initial and gets most air out of the system.
Old Oct 19, 2019 | 05:06 PM
jackra_1's Avatar
Not too high on one corner because of the danger of Aluminum body "twisting".
95 Cat
Sep 18, 2019 01:26 PM
murray2200
Oct 28, 2017 03:35 AM
newjagowner
Oct 5, 2012 04:44 PM
plums
Jul 8, 2011 01:33 AM
yeldogt
Jul 30, 2010 01:16 PM
