4.2 XJR overtakes S-Type R
Greetings,
So I read that the curb weight of a XJR is just ~3700 lbs whereas a S-type weighs at ~4000 lbs. This gives ~30hp advantage right there. Is this true?
Although the handling of S-type R would be superior while cornering, I suppose; esp. with those gorgeous wide tires.
Is it possible to get ECU tune for XJR USA MY03 or is the ECU tunable after MY07 ? ( I was told about this limitation by EuroToys)
Thank you
Thank you
thisguy
Apr 22, 2008 05:49 AM
