97 vdp central locking system
I was trying to find a draw on my batterie.I disconnected the positive side and put a ampmeter between the positive terminal and positive cable to read the draw.I then unplugged one fuse at the time to see if I could find the draw.I never did,but now ,the central locking system and alarm are not working anymore.I cant even open the trunk electronically.I rechecked all the fuses,and they all are good.What could be the problem????
Personally, I would have removed the negative clamp from the battery as opposed to the positive when checking for current draw. In any event, try disconnecting the negative clamp from the battery, leave it disconnected for about 20 minutes and then reconnect the negative clamp.
aholbro1
Dec 29, 2024 06:46 PM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
Nov 23, 2015 01:56 PM
Mbourne
Sep 14, 2015 09:21 PM
