ABS connector? ABS removal
Old Jun 16, 2019 | 07:02 AM
ryejag's Avatar
Default ABS connector? ABS removal
I want to reseat my ABS connector on my 2004 XJR. Has anyone done this? or replaced their ABS unit? Its a large connector and I want to be sure that I do not damage it while attempting to remove it.
Old Jun 17, 2019 | 05:45 PM
meirion1's Avatar
Maybe disconnect the battery first just to be on the safe side?
Link refers to X300
https://www.jaguarforums.com/forum/x...-fault-112055/
Old Jun 19, 2019 | 01:52 AM
Datsports's Avatar
Link refers to X300
good tip with the battery .
i checked that link . the connector is a different description than ours on the later cars , there is no bolt ,
just a lever to pull out . and the leaver simultaneously extracts the plug 3/4 out .
Old Jun 24, 2019 | 10:24 AM
BlackKat's Avatar
Expect that plastic lever to be brittle.
Old Jun 24, 2019 | 10:52 PM
MrWhite's Avatar
When I looked into replacing the ABS sensor, I found it was cheaper to replace both front wheel hubs and bearings with sensors built in than it was to replace just a single sensor. Crazy!
https://www.ebay.com/itm/Set-of-2-NE...72.m2749.l2649
car5car
Aug 12, 2019 06:33 PM
Amphicar770
Jun 21, 2019 12:19 PM
David F.
Dec 26, 2018 03:21 PM
philwarner
47
Jul 28, 2016 03:29 AM
user 84302
May 3, 2016 07:47 PM
