ABS module..
Old Aug 7, 2012 | 07:40 PM
tilbury's Avatar
Default ABS module..
Where do I find the ABS module on a 2000 xj8. That anoying light stays on in my dash. I have checked the wheel sensors at the plug. If the module is the large flat black thing the plug goes into can I remove it without getting brake fluid everywhere? How can I test it to be sure that is what my problem is.My mechanic says it might be the problem but I hate to keep throwing money at his guesses.
Old Aug 7, 2012 | 08:02 PM
Gus's Avatar
Gus
This link to my page for ABS Repair is for a 1999 xk8 however the pattern for testing will help narrow the problem down
JagRepair.com - Jaguar Repair Information Resource
Hope this helps.
Old Aug 7, 2012 | 09:51 PM
motorcarman's Avatar
You are in the wrong section of the forum.
You need to post this in the X308 forum to get a better response from members.
bob gauff
Old Aug 8, 2012 | 07:53 AM
tilbury's Avatar
Thanks for the photo instructions. this info has made my day.
Old Aug 8, 2012 | 08:05 AM
tilbury's Avatar
I posted here because my car is a 2000 xj8- vdp. Sorry if I did not make that clear.
Old Aug 8, 2012 | 08:07 AM
tilbury's Avatar
I didn't notice about the years applicable bit.
Old Aug 8, 2012 | 09:45 AM
tilbury's Avatar
I started after 9:30 and now it is 10:30. The module is clamped up waiting for the glue and silicone to cure. I had more problem finding the right tools and trying to get the bottom 2 screws out than anything else. On my 200o xj8 it was even easier to get the module past the brake lines becuase they could bend out of the way easily. The actual problem was just as described in the repair instructions. Sometimes ya get lucky.
goges
Oct 5, 2015 04:53 PM
millertic
Sep 30, 2015 08:11 PM
leep123
Sep 30, 2015 03:41 PM
mrplow58
Sep 30, 2015 08:56 AM
