Adaptive cruise
Old Feb 13, 2024 | 02:40 PM
MartinM.no's Avatar
Default Adaptive cruise
My adaptive cruise is not working. When it is cold outside I get a cruise not available code. When warmer the code disappears, but I still cannot engage the cruise control.
When code is not present the driver alert system works as intended. This indicate to me that there is nothing wrong with the radar part of the system.
Today I scanned the car for codes and following code is present; p1696 speed control input switch fault- not cancel. Adaptive speed control can link adaptive speed control fail.
Any suggestions to what is wrong. What and where is the speed control input switch?
Suggestions are welcome.
br Martin
Old Feb 14, 2024 | 03:57 PM
JCalhoun's Avatar
See if it's the switch on the brake pedal that tells the cruise control system that the brake is not applied. I have heard of a number of cases where slightly high resistance, or an occasional intermittent in this switch will cause the cruise control to lock off.
Good Luck
Jeff
Old Feb 14, 2024 | 05:09 PM
Jaroslav Záruba's Avatar
An absolutely spectacular guide on how to inspect and repair your ACC, from the same guy who created JagDroid:
https://sites.google.com/willcoxonli...uar-acc-repair
Old Feb 15, 2024 | 12:19 AM
MartinM.no's Avatar
Thanks for advice.
I will try the brake pedal switch. Bought a spare one.
I do not think it is anything wrong with the radar itself as the forward allert system works fine. The buttons on the steering wheel also seem to work as I can atleast adjust the distance in the forward alert system.
br Martin
George Abitbol
Mar 5, 2023 04:17 AM
Dukejag
May 5, 2020 09:39 AM
Mediawiz
Aug 15, 2019 03:40 PM
Diddion
Jun 9, 2017 05:42 AM
QuikCat
Mar 20, 2014 10:27 AM
