air con one side not working
Old Sep 26, 2021 | 06:09 AM
jjayp's Avatar
Default air con one side not working
Hi all
2004 JAGUAR XJ6 V6 SE AUTO 3.0 Petrol
I recall a post a while ago on aircon not working properly on one side.
In simple terms : drivers side when its hot outside, no 'cold' air comes through(passenger side works with cold air coming through), when its cold outside no hot air was coming through (passenger side functions normally).
Lookers have been pretty hopeless, topped up refrigerant, still doesnt fucntion properly. I do get volume of air coming out just not the correct temperature.
So in the summer the car is stuffy and hot and in the winter its like an iceberg om wheels !
Any pointers would be appreciated. No fault codes showing.
Jason
Old Sep 26, 2021 | 12:58 PM
FreeWifi's Avatar
Sounds like heater core replacement is in need. Flushing usually doesn't help if it was never done in the past. When not regularly flushed coolant sits in the core pipe and sludge builds up until it finally blocks the pipe. By the time this happens a flush is rather useless. One side of the core pipe feeds the driver side and the other the passenger side. Unless there is always someone in the passenger seat you may not notice the temp difference occurring until it affects you.
Old Sep 26, 2021 | 08:26 PM
meirion1's Avatar
It sounds like a common fault where the heater matrix is partially blocked.
Replacement should resolve heat problem but you may then have a problem with
cold air because of a heater flap inside the climate 'box'.
Old Sep 27, 2021 | 11:08 AM
jjayp's Avatar
Thanks, I'm ok with normal maintenance etc but I presume this is a pretty specialised job, would an AC specialist be better as main dealer were hopeless? Anyone have any recommendations for London UK or Essex UK, in fact anywhere in the South UK or East?
Many thanks
2008xk
Aug 19, 2021 10:54 AM
gtunstal
May 4, 2018 08:09 PM
docproc
Jun 28, 2017 10:29 AM
Francesca
101
Jun 14, 2015 07:23 PM
Noxparadise
Jul 26, 2013 08:24 AM
