Air suspension
Old Mar 5, 2010 | 07:39 AM
user 2029223's Avatar
Banned
Reletive to the JTIS, I notice that it contains no part numbers. Where does one go to look up part numbers anyway?
Reletive to the characteristic ride/handeling of my 05 XJR over an XJ8, is that a function of computer programing or different suspension components? For instance, I can surmise that the anti roll bars are different but what about the air shocks? Are they different part numbers on an XJR as opposed to an XJ8?
These are important questions, especially if you are trying to buy parts off the internet or EBay. You spend more time trying to decide if buyer and seller are talking about the same item than the condition of the item.
Old Mar 5, 2010 | 11:24 AM
H20boy's Avatar
Parts catalog IS INCLUDED on this 2005 CD...check it out
Old Mar 5, 2010 | 11:32 AM
BuckMR2's Avatar
I have the 2005 EPC (Electronic Parts Catalogue) and its an absolute nightmare to use. First off you have to put your PC date back to 11/2004 so it can cause big problems with windows or any other programs running in the background.The part numbers listed on it may not be correct as part numbers can change (superceed) regularly.In order to get current part numbers you need to be a dealer with a pasword connected to Jaguar parts system which none of us are.
I tried buying later updates to my EPC from ebay but they turned out not to be updates at all and the ebayers were banned from ebay after complaining presumably for misadvertising.
Im not saying the EPC listed above wont work but you may be taking on problems if they are anything like the ones I had (which wouldnt run on Vista either).
Old Mar 5, 2010 | 01:41 PM
H20boy's Avatar
^^^AAAGGHHH
Good thing I'm not buying it for the parts references! I'll see if it works any better on my XP machine.
Surely there's a way to 'pdf' all of the catalogue information...maybe, even if you have to set the clock back once to do it. I'll play with that option too. Update ya later...my cd hasn't arrived.
Old Mar 5, 2010 | 01:47 PM
BuckMR2's Avatar
Putting to pdf would be nigh on impossible I think
There are 1000s of parts for each car and even more when working out the part number from the VIN
VIN ID is a feature on the EPC so you can scroll to the correct part for a particular car and what it had from factory including trim codes,options, features etc
Old Mar 5, 2010 | 06:10 PM
Banned
So let me get this straight--- as a practical matter, there really is no currently available parts catalog for 04 and up cars unless you are a Jag dealer.
Does anybody happen to know if XJR air shocks are a different part no. from XJ8 air shocks in general?
Old Mar 6, 2010 | 03:23 AM
the-pm's Avatar
I believe they can be different, there is a high volume version for a softer ride and a low volume version for firmer ride. So and XJ8 Sport would have the same shocks as a XJR but an XJ8 SE would have different shocks, best to check the part numbers mind to be sure.
Philip
Old Mar 6, 2010 | 04:01 AM
  #28
BuckMR2's Avatar
Ask your dealer
philwarner
25
Jun 26, 2021 05:43 AM
Forcedair1
Feb 19, 2020 01:51 PM
scooternva
19
Oct 27, 2015 02:14 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
Andrew Fanshawe
Sep 14, 2015 07:40 PM
