Air Suspension Question-Cant Start Car
Old Aug 10, 2022 | 10:52 AM
XxSlowpokexX's Avatar
Default Air Suspension Question-Cant Start Car
Ive had one of my XJR's sitting for over a year. It slowly leaked out the air in the bags over that time. Issue is the fuse for my ECU keep popping and I cant start the car (why its sitting). I pulled the ECU out and the fuse still blows....I havent the time to dig into this so I planned on getting it towed. However its too low.
So the question. Anyway to lift the car without starting it?
Thanks All!
Old Aug 10, 2022 | 02:52 PM
I generally have the "noone has an answer to" Questions. But I figured it was worth a shot.")
Old Aug 10, 2022 | 03:08 PM
ChrisMills's Avatar
People sleep for 4hrs!
Old Aug 10, 2022 | 03:39 PM
flatsix's Avatar
If you have SDD you can do this without running the engine, there is a menu to fill and drain the air struts.
Dont know wether it works even if the ECU fuse is blown and a short circuit disables the control unit.
Old Aug 10, 2022 | 06:26 PM
Still have yet to get a copy of SDD working. Ill see if I can get someone to stop by with a copy. Im sure some crossing or wires would work but I haven't a clue which. The fuse thing is killing me
Old Aug 11, 2022 | 03:38 PM
flatsix's Avatar
Which fuse exactly gets blown and what MY is your car? Is it possible that rodents could have been on her while she was sitting?
Old Aug 11, 2022 | 04:30 PM
I have two 2004 XJR's. I lent one to my buddy for the past few years as he had no car to drive. He went through a puddle last year and the car died and would not restart. Its been awhile since I checked but its the ECU fuse in the engine compartment fuse box. Its fuse 17. So being it still blows with ECU disconnected it may be something related to the transmission wiring somewhere. This happened before sitting. It was sitting because of this. I really didn't get into the fuse thing here because I got some good advice I just haven't found the time to dig deeper. 2004 XJR BIG ISSUES Electrical? Can Bus? - Jaguar Forums - Jaguar Enthusiasts Forum Could be a ground issue....I can tell you my other xjr HAS a ground issue..Its never ending...For now I need to raise it up to get it towed to the shop. If I can get it fixed ill just give him the car.
Old Aug 12, 2022 | 01:06 AM
flatsix's Avatar
Yes, that is the power supply (Batt +) of the ECU, if that fails not much works . This is certainly a ground fault, but you can find it. Starting from the front distribution fuse box connector EC40 (8 pin, black) brown red cable with two more plugs to the ECU connector, pin 22. There should be continuity to ground to be measured.
I do not know if the air suspension modules without communication to the ECU with SDD can be triggered, you would have to try.
good luck
Fritz
Old Aug 12, 2022 | 09:05 AM
Wingrider's Avatar
If you have access to a floor jack that can fit under to access the frame.
Connecting battery voltage to the air pump might work.
Old Aug 12, 2022 | 12:51 PM
nebelfuerst's Avatar
You could lift the car by putting pressured air into you airbags by opening the hose close to the suspensions.
This would also require valves to keep the air in the bag.
If SDD can talk to airsuspension, you can also open valves to raise the car. ( I remember it was two buttons raising front and raising back.)
You need pressure in the reservoir which is located under the spare wheel.If your compressor doesn't start, you could also blow pressured air into a hose here.
Old Aug 13, 2022 | 11:16 AM
clubairth1's Avatar
Community Influencer
Another vote for possibly powering up the compressor externally like Wingrider suggested
Not sure it would work so it's just a guess. Tough spot to be in.
Let's hope it is a ground issue and as you probably already know those ground studs will shear off if you just look at them! Very tender parts. Just screwing the nut on and off the stud can easily twist the stud right off the car. If possible hold the threaded part while you get the nut loose.
I have replaced a number of ground studs and use a cut down stainless steel bolt/screw to replace the very weak factory studs. Now it's a strong connection and you can properly tighten the ground wires.
Don't forget you can easily run a temporary ground wire too. Just to troubleshoot your problem.
Do you know where the ground studs are? There are a number of them and fairly well hidden.
JayJay
74
Sep 25, 2023 09:48 AM
01Silverstone
Jun 17, 2018 06:26 PM
4thjagandstillgoing
Feb 26, 2018 04:20 PM
Arbus
Jan 9, 2012 10:05 PM
2564james
Jun 20, 2010 09:59 AM
