Airbag flash codes
Old Dec 28, 2012 | 05:26 AM
lotuscorty's Avatar
Default Airbag flash codes
Hi, does anyone have a list of flash code descriptions for the X350??
I have a code showing 46? and I would like to cure the problem.
Any help most appreciated.
Old Dec 29, 2012 | 08:37 PM
motorcarman's Avatar
Page 23
bob gauff
File Type: pdf
Old Dec 30, 2012 | 05:07 AM
lotuscorty's Avatar
Thanks, very helpful.
Rear crash sensor.
Tried changing this sensor with another one I know is ok, but still the light is on.
Does the system need reset with diagnostics? Thanks
Old Dec 30, 2012 | 06:14 PM
I have no idea. I have WDS and IDS so I would clear the DTC. If it is a HARD fault then it won't clear.
I would then read the continuity with datalogger.
It could be a harness fault.
You might unplug the sensor and check the harness continuity from the SRS module connector.
bob gauff
Jpav27
Jul 31, 2022 06:43 AM
Iain Yates
Sep 16, 2015 06:48 PM
Johnken
Sep 15, 2015 05:46 PM
tonyforman
Sep 10, 2015 07:23 PM
mrplow58
Sep 9, 2015 11:27 AM
