Alpine Subwoofer Check?
Old Oct 30, 2022 | 10:06 PM
JaguarXKR's Avatar
Default Alpine Subwoofer Check?
Hi All,
I am not looking to remove the subwoofers (removing the rear partial shelf). But I am curious is there a way to get to the subwoofers form the trunk area or is there an easier way to check that both subwoofers are working properly without accessing them?
Thanks!
Old Oct 31, 2022 | 09:59 AM
wfooshee's Avatar
This just came up earlier this month!
Old Nov 6, 2022 | 01:21 AM
zakchary's Avatar
Originally Posted by JaguarXKR
Hi All,
Thanks!
i'm also facing same issue. what to do now?
Old Nov 6, 2022 | 01:22 AM
zakchary's Avatar
Hi All,
Thanks!
if you got solution please reply here.
Old Nov 6, 2022 | 12:24 PM
JaguarXKR's Avatar
Not yet.
Old Nov 6, 2022 | 06:47 PM
wfooshee's Avatar
See, in that thread I linked in post 2, the post 5 in that thread describes removing the trunk trim to get to the subwoofers. They cannot be removed from the trunk, but you can get to the. Pulling all the trim is a bit of a job, and not much easier than removing the back seat and the parcel shelf...
I actually replaced mine with an aftermarket set, and had to do both the interior and the trunk trim, as I had to drill new screw holes.
Old Nov 8, 2022 | 07:39 AM
JaguarXKR's Avatar
Hi There!
Thanks for the response. I am not looking to remove my subs at this time. Just check to see if both are working properly. I have the powered rear seat and don't want to risk causing issues removing the seats until I know I have a problem. From the trunk area were you able to see the underside of the sub after you removed the trim?
Thx!
Old Nov 8, 2022 | 09:17 AM
wfooshee's Avatar
Hi There!
Yes
Old Nov 8, 2022 | 10:43 PM
JaguarXKR's Avatar
Yes
Are you able to help me figure out how to remove the correct trunk trim liners?
Thanks!
Old Nov 9, 2022 | 02:48 PM
wfooshee's Avatar
Pretty much all of them except the inside of the trunk lid. The rearward panels overlap the ones ahead of them, and the side panels overlap the panel under the parcel tray. There are several big plastic button retainers to pry out, so get one of those tools made for that; it makes life much easier. Basically a 2-prong fork.
The worst part is getting them back under the rubber gaskets when they go back in.
omgimali
Apr 9, 2026 09:00 AM
JaguarXKR
Oct 11, 2022 08:20 PM
King Leonard
Jul 29, 2020 06:35 AM
mexicanhifi
Jun 5, 2020 12:18 PM
tcage
Apr 10, 2011 10:50 AM
