Auto Up Feature
Old May 4, 2013 | 11:38 AM
PSkrause's Avatar
Default Auto Up Feature
The power window on the driver's door on my 2007 XJ still has the Auto Down feature but suddenly the Auto Up feature doesn't work. Is that odd that it only works in one direction? LOL but you'd think the damn thing would have a longer life expectancy than just 70K miles.
PK
Old May 4, 2013 | 11:43 AM
BlackX300VDP's Avatar
you can reset it. simply close the window completely and let go of the up button. Then, hold up on the up for about 10 seconds. Then just check it. Might as well do the same to all the windows since it is easy and ensures they are all working properly.
Old May 5, 2013 | 04:37 AM
James Lewis's Avatar
They can break a lot of people have had to replace them. My switch broke so took it apart and found it is made of two parts, as they age the tangs holding the one piece down snap due to thin plastic. I found if I held the 2 parts together and wrapped with electrical tape and some glue, then the second click of the button cold be felt again and be one touch once more.
Old May 5, 2013 | 12:54 PM
PSkrause's Avatar
Default It worked. Thank you
Well that was an easy fix. I was able to "reset" the window switch. You saved me a bunch of cash. Many thanks
MonacoDK
Jan 22, 2022 12:33 PM
Rocky15
Oct 12, 2015 03:42 AM
k-man
Oct 5, 2015 08:09 AM
buickfunnycar.com
Sep 25, 2015 10:02 AM
