Battery was quite low
Old Feb 17, 2021 | 09:06 PM
jean HJ's Avatar
Thumbs up Battery was quite low
Hello folks
I need a tipp
the battery from my xj8 was quite low today after my detailing session with a running radio.
After first start the following messages occured on dash display I think it's something with .the automatics headlights .If I turn the headlight switch to the "off" position I get a messages saying "lights off" in the message center I haven't had this before May a reason from low battery? Or is it a sensor who recognise that's dark outside to let you know to turn on the lights when turn ignition on may its a standard feature and I haven't ssen this before?
Many thanks Jean
Old Feb 17, 2021 | 09:10 PM
Six Rotors's Avatar
You get that message when the light switch is in the off position when you switch the ignition on---it is a standard feature on my 2004 Vanden Plas.
Old Feb 17, 2021 | 09:18 PM
jean HJ's Avatar
Thank you very much for the quick response
Grumpy Finn
Nov 27, 2021 01:17 PM
1r1sh
Sep 16, 2016 01:31 PM
Palmero
XJ40 ( XJ81 )
Feb 17, 2014 10:30 AM
Deanman
Jul 1, 2011 04:58 AM
