Belly pan :(
Old Jul 22, 2010 | 10:41 PM
haggis95's Avatar
Default Belly pan :(
My belly pan got hung up on a kerb I damaged it backing up off the kerb.
Couple of questions:
Can I take it off myself?
Should I replace it?
Old Jul 23, 2010 | 09:12 AM
user 2029223's Avatar
Banned
Yes you can replace it. Only common hand tools required. You will need ramps or jack stands.
Yes you should replace it as it's important for high speed driving/handeling.
Interesting question is; what other benefits accrue from use of belly pan? Perhaps someone else can shed a little light on this.
Old Jul 23, 2010 | 09:53 AM
haggis95's Avatar
Actually I should be more clear - the belly pan is fine, it''s the engine bay undertraythat I've got zip-tied up since my hang up on a kerb.
Old Jul 23, 2010 | 10:34 AM
amcdonal86's Avatar
It probably also affects proper cooling/airflow into the engine at highway speeds.
SD96XJ6L
Dec 27, 2025 09:58 PM
Joachim1167
Nov 7, 2020 09:18 PM
LnrB
Oct 13, 2015 12:45 AM
dmatthewman
Sep 30, 2015 10:10 AM
