Bluetooth
Old Nov 12, 2017 | 02:00 PM
All4Jags's Avatar
Default Bluetooth
I Have a 2007 XJ8 VP and I have been reading comments and forms about Bluetooth connectivity my
problem is that the connectivity is intermittent!
sometimes the phone connects immediately when I get to the car and sometimes I have to force the connection thru the setting on the phone several times up to 15 minutes before a connection can be established
I tried a different device with no luck
I uninstalled the device several times pushed the phone button on and off but no luck
watched YouTub for similar issues any advice from the x350 owners?
Old Nov 13, 2017 | 09:50 AM
Sean W's Avatar
What do you mean by a different device? Phone or module? When you say you have to force a connection through the phone several times up to 15 minutes, what specifically do you mean? Is you phone not finding the Jaguar in bluetooth or - finding it but not connecting or - connecting but not pairing?
As I don't have the X350 anymore, bear with me. Is there a time out to home screen when you're on the phone screen? In other words, does your Jaguar give up after a short time trying to find a phone?
On the XK, there is a timer and after so long, the phone screen stops trying to connect. To alleviate this, we simply extend the time out to a longer period. This is in the systems or vehicle setting. I don't recall which and like I said, I'm not sure it's relevant to your make/ model.
Old Nov 13, 2017 | 10:24 AM
All4Jags's Avatar
Thank you, Sean,
different device i mean a different Phone, both Android and I Phone
there is never a message that says trying to connect it's either no BT phone or connected
i don't have an option in the car setting for timeout unless it's on a non-user level?
Old Nov 13, 2017 | 10:53 AM
allginandjags's Avatar
Is the poor connection always in the same place? ie does it connect more easily in some places than others? Perhaps some local interference?
