Bluetooth audio?
Old May 14, 2012 | 10:55 AM
josh_77073's Avatar
Question Bluetooth audio?
can you play music from your phone via bluetooth? if so how do you setting up?i have my phone Bluetooth connected for phone use already.
Old May 14, 2012 | 11:50 AM
Sarc's Avatar
Unfortunately not.
You need to fit at least an ACM (Audio Connectivity Module), which gives you an aux in, then you can add bluetooth capability to that in various ways, ie add a Motorola T605 http://www.amazon.com/Motorola-T605-.../dp/B000N85PLS, or add a bluridge adaptor BluBridge mini-jack Rx | Miccus Wireless Audio Solutions
This thread https://www.jaguarforums.com/forum/x...fficult-44942/ has a lot of useful info
Old Jun 2, 2012 | 11:12 AM
izzodesh's Avatar
sarc- great post thank you!
If i get it ..if you add the miccus you can keep in the glovebox and then have the bluetooth of your exisiting factory head unit/BT connect with BT on ur iphone?
thanks!
-dave
Old Jun 2, 2012 | 12:04 PM
Sarc's Avatar
@Dave
I started out with the Miccus and while the sound quality was good, it did not automatically reconnect if you got out of the car and then came back. This required you to press the button on the miccus each time to re establish the connection. Now, that may have been a function of my Android phone and you may get different results with an iphone, but I then got the Motorola T605 and it solved all my problems. I have since changed cars but the first thing I bought for the new car was a Motorola T605 and will be fitting it very soon
Jagzzz
Aug 8, 2021 02:45 PM
King Charles
Oct 16, 2015 01:25 AM
Msteiner
Audio/Visual Electronics
Sep 30, 2015 08:36 AM
Rocky15
Sep 28, 2015 04:59 PM
