Boot/Trunk Stuck - Can't Fully Open, Can't Fully Close
Old Dec 31, 2008 | 06:30 AM
rashaw's Avatar
Default Boot/Trunk Stuck - Can't Fully Open, Can't Fully Close
Hi,
I have a 2004 XJ8 and recently the boot has become stuck. The car was unlocked and I was leaning on the boot when I accidentally pressed the release button on the boot.
Instead of opening fully, the boot released the motorised lock but has stayed latched, so it opens about 0.5 cm.
When I push it closed, the motorised lock does not operate and when I try the boot button, key fob or in-car button the boot does not release. Also, using the key on the boot lock above the plate does not work either.
So, I'm stuck [&:] and the car thinks the boot is already open and refuses to centrally lock using the fob (I need to manually lock using the key).
Any solutions to this? I don't think it is an electrical failure apart from the car being confused as to the state of the boot.
Thanks,
Rob
Old Dec 31, 2008 | 02:30 PM
KYBlackCat's Avatar
Default RE: Boot/Trunk Stuck - Can't Fully Open, Can't Fully Close
Maybe try the emergency tab...the one in case you ever found yourself locked in the trunk.
Just throwing out and idea... Good Luck!
Old Jan 1, 2009 | 03:57 PM
hlgeorge's Avatar
Might try the full reboot. Disconnect the pos battery cable and let it sit for a few minutes. Touch the pos cable to the neg cable a second before reconnecting to pos cable to the battery. You will reset everything in the car and will have to reprogram them, but may also reset the confused trunk module.
Old Jan 5, 2009 | 11:40 AM
rashaw's Avatar
Update:
The boot lock seemed to reset itself after about 12 hours as the next morning it opened OK using the button on the boot.
However, being partially open the battery was discharged and I was no longer able to start the engine. So, I gave it a boost from a main charger and all seems OK.
I think the battery discharge was due to the boot being partially open, but I have a nagging suspicion it was due to the CD changer in the boot as I put a new CD in just after I managed to open the boot. Just a suspicion but it seemed to wirr for a while after the new CD was added to the cassette.
Another irony was that the boot was stuck again last night but this time was due a drop in temperature after rain. The boot seal was frozen to the body and once again I could only partially open it. This time some warm water did the trick.
Old Jan 5, 2009 | 10:51 PM
KYBlackCat's Avatar
Well, at least it seems to have sorted itself out for you..
Old May 7, 2012 | 09:07 PM
lenalittle's Avatar
I am now having this same problem. I also have a 2004 XJ8. I haven't tried disconnecting the battery yet. I'll try that tomorrow. If that doesn't work I'll try to get into the trunck from the back seat and pull the latch. Any other suggestions? Thanks.
Old May 8, 2012 | 11:16 AM
freebeeme's Avatar
next time open the boot with the key and just close it the normal way.
Old May 8, 2012 | 07:37 PM
lenalittle's Avatar
freebeeme,
This is my first Jag and I have only had it a few months. I couldn't find the key hole for the trunk. I found it earlier this morning and was able to open it using the key then shut it normaly. All seems ok now. I think I am having CAT system issues because when I started it up prior to resolving the boot problem, it threw out all kinds of system error messages and the power steering was not working. It was hard to turn the steering wheel. Anyway, I think all is ok for now. I have alot to learn about my jaggie
Thanks,
Lena
99xk8guy
Sep 29, 2025 10:51 PM
dsnyder586
Dec 29, 2024 07:39 PM
99xk8guy
May 28, 2024 09:36 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
findre
Sep 10, 2015 05:46 PM
