Boot will not pull down and latch 2004 xj8 - Resolved
Old Oct 20, 2012 | 11:19 AM
tiaaa's Avatar
Default Boot will not pull down and latch 2004 xj8 - Resolved
Boot will not pull down and latch, getting a boot open warning, when i push trunk button i can see it pulls down the trunk but it pops back up.
any ideas? tx
Old Dec 2, 2012 | 09:20 AM
thecoveneys's Avatar
I have the same trouble with my 06 S Type. I popped open the boot and now it won't latch closed - also boot lights stay on. Can anyone help please?
Old Dec 2, 2012 | 04:12 PM
meirion1's Avatar
First thing take the bulb out of the boot light.
If the rest of the central locking is working then it is not the fuse.
It is possible (but not likely IMO) that there is a break in a wire where it bends when you close the boot lid.
In the boot lid you have a small electric motor and three microswitches.
I think this is accessed via the black plastic around the latch on the lid.
Possible faulty microswich or motor.
BTW this post applies to an XJ, S type might be similar.
Let us know how you get on.
Old Dec 4, 2012 | 03:06 AM
Smile Boot lock fixed
HI Meirion,
Thank you so much for your thread.
Taking the bulbs out would seem to be a no brainer, but I hadn't thought of it, having put the car on charge over night.
I levered off the black plastic lock cover - one little lug on each side, then took off the large cover containing the boot lid light, held in by a 8mm bolt each side, hidden by a plastic cover (one missing).
I could then see the lock mechanism move slightly when pushing the remote.
So no electrical problem.
The lock is held in with two hex bolts. As it comes out you need to fiddle it through the hole then it just unplugs.
It was a bit dirty, so I cleaned it up with WD14. There is a cream coloured plastic lever that sticks out on the rear facing side of the lock. This can is the manual lever (which could be linked to a cable) and seemed to be sticking to the lock casing. A bit more WD everywhere, then a bit more and it suddenly came free.
Working like a nicely oiled pistol, I connected it back to the car and using a screw driver to push the latch closed, activated it several times with no problem.
I tried connecting a plastic tie to the lever (as seen in the article about x type boot locks) but this seemed to snag, so I left it out. I put it back in and tested it several times before putting back all the trim.
I have a few pictures if any one wants to see them.
As I was on a roll, I then took out the trim in my '99 XK8 and thanks to the WD40, got the key mechanism working (more pics).
Thanks to everyone who adds threads - we must all be saving a fortune in garage bills and a special thank you to Meirion.
John
dsnyder586
Dec 29, 2024 07:39 PM
tomsjag
Jun 10, 2023 10:02 AM
kevinl
Oct 31, 2019 06:15 PM
Sambo21
Nov 19, 2015 03:55 PM
jimbo1948
Sep 7, 2015 03:14 AM
