Which bushings this time?
Old Mar 25, 2018 | 10:11 PM
Dan R's Avatar
Default Which bushings this time?
I can hear an audible, light thud when I first apply the brakes after moving off. I hear a similar noise when the front end goes over speed bumps (slowly).
What worn components should I be checking for?
Old Mar 28, 2018 | 08:19 AM
ayavner's Avatar
Might start with the sway bar bushings there. Or possibly the air strut mounts (top and bottom)
what does the thud sound like, is there a metallic ring to it?
Old Mar 28, 2018 | 09:16 AM
Dan R's Avatar
What does the thud sound like, is there a metallic ring to it?
It is a light, muffled thud, not felt. Not metallic. It is almost as if the brakes have split second pause and then they bite. Similar sound when I go over speed bumps.
I have ordered the ball joint boots from Bulgaria via eBay to replace the upper control arm boots that have just rotted away. This will be a good chance to have a look at all the usual suspects.
Ingo85
Oct 20, 2022 03:56 AM
FastKat
Jun 27, 2014 01:46 AM
FastKat
Jun 10, 2014 04:14 AM
Farmer J
May 30, 2014 07:53 PM
