cant get my one touch windows operation to work
Old May 20, 2011 | 09:57 PM
Jsedita74's Avatar
Default cant get my one touch windows operation to work
the back windows work as i feel a kinda click but in the front window switches i dont feel a click and they dont work up or down... any ideas? is it the switches or maybe a programming issue? thanks fellas
Old May 21, 2011 | 03:36 AM
u102768's Avatar
Have you tried this?:
Fully close the window, hold the switch in the close position for two seconds and then release the switch.
Wait for two seconds, do not open the window.
Again, select the same window to close, holding the switch for a further two seconds.
Check to confirm the operation by opening the window and then use one-touch operation to close the window.
Repeat for the remaining electrically operated windows.
Old May 21, 2011 | 02:04 PM
Jsedita74's Avatar
what about to one touch open it? is it the same basic function but reversed?
Old May 21, 2011 | 04:18 PM
u102768's Avatar
I believe that once you have reset as per the instructions your one touch should work both up and down.
I have seen someone else find that their one touch was broken though and I think that turned out to be the switch.
Old May 22, 2011 | 02:13 AM
Jsedita74's Avatar
that did not work. i can feel the 1 window that does work click up n down where as the other 3 buttons do not click ... is it maybe they arent seated properly some how? how do i take apart the main control section on my driver side door to inspect?
Old May 22, 2011 | 03:17 PM
Jsedita74's Avatar
Ok so I noticed today that the one touch feature works on the windows if you use the individual buttons for each window but none work from my main control in the drivers door . I tried to reprogram but to no avail. Only 1 window actually works from the driver seat (rear driver side) am I doing something wrong? What position does the key have to be in ? Should the car be running?
Old May 22, 2011 | 04:04 PM
hlgeorge's Avatar
I had to have the main switchpack replaced on my car. Thankfully it was still in warranty when it failed.
Old May 22, 2011 | 05:10 PM
Jag Breeder's Avatar
Thats what ill recommend a new pack to but if you wanna save a few $$ you might be able to check take the switch and diagnose the problem and if it get too complicated you can first start seing if they have your model/year at a local savage yrd and compare price from some on the net (ebay) and you can replace the whole unit yourself that way you dont have to pay all that money for labor and all that other outrageous hope this help
Old May 22, 2011 | 05:26 PM
Jsedita74's Avatar
is it difficult to remove and inspect?
Old May 22, 2011 | 05:43 PM
Naw just take of th edoor panel and you'll see the switch pack take out a few screws and there you go
Old Jun 1, 2011 | 02:39 PM
amcdonal86's Avatar
Mine started acting up a couple weeks ago. I just "exercised" it back into shape. Just start playing around with it--seems like gunk under there can cause it to become unreliable.
Old Jun 1, 2011 | 02:46 PM
Jsedita74's Avatar
Is there any way to get in and clean them or should I just play w them?
philwarner
Oct 4, 2024 01:37 PM
JakeXKE
E type ( XK-E )
Jul 6, 2021 06:49 PM
XJsc-guy
Nov 23, 2015 01:56 PM
laserguy
Sep 3, 2015 02:02 PM
XJsc-guy
Sep 2, 2015 11:43 AM
