cats total shut down
Old Dec 18, 2018 | 05:03 PM
stevengottfried's Avatar
Post cats total shut down
For quit a while i get more frequently failure messages like dsc failure, abs failure, engine light on, air suspension failure etc. But now from time to time i start the engine and after 10 seconds all failure lights go on and the gearbox lock up, and all odometer or rpm readings stop, but engine keeps running.When try to restart the engine, nothing happens.Luckily after a couple of hours the car starts all works except the engine failure signal goes on, but after a couple of runs and restarts the engine failure light disappears, everything works no warning signal.After a couple a maile various different signals go on, as air suspension failure, dsc, failure, parking break failure reappear but the car drives perfectly normal.
After reading the thread i dont sign its a solenoid at the air suspension or any other particular connector problem. The battery is a year old, any suggestion, is there a kind of motherboard or chip which needs to be replaced. I would be thankful for any hints how to fix it. I have a shop mechanic specialized in Jaguar,(mostly classic modells, but who did a good job over the years( inspections, brake wear and tear issues. I stay away from jaguar dealers who charge outrageous hourly rates and just charging for reading error messages 100 euros, and usually refuse to give estimates and consider the car as to old even thou it is well maintained and very good shape.
Thanks Steven
Old Dec 18, 2018 | 05:38 PM
Fraser Mitchell's Avatar
You need to get the fault codes read for a start. This needs a reader which can be bought on the internet, but you must get one that can read Jaguar-specific codes. It sounds from what you say that your shop mechanic is not up-to-speed on this, only traditional Jaguar stuff. This is OK if he sticks to the older Jaguars but no good with modern stuff which has very complex electronics. For dsc, and abs faults, a common cause is one of the wheel speed sensors failing in the hub carrier. Cheap to buy and fix but you must know which one, hence the need to read the codes. Frankly, unless you get the codes read you will be in the dark. The first thing to do is to delete them all and start with a blank memory and then read the codes as they occur. I think you have more than a single cause for what is happening. Are your earthing points on the front of the car in good order ?There are three, two behind one headlight, and one behind the other. Failure of these can cause all sorts of weird happenings.
Old Dec 18, 2018 | 08:38 PM
34by151's Avatar
Codes may also be a reaction to the issue and not the issue itself
I would check
1. The three earths behind headlamps
2. Battery condition
3. J-gate
All 3 will produce some or all of the issues you are having
Have codes read, and cleared then read again after issue reoccurs
34by151
bhurock123
35
Jul 22, 2019 09:25 AM
RobGardnerBlack
May 7, 2018 12:42 PM
Stubbyxj6
XJ40 ( XJ81 )
Jun 29, 2011 07:09 AM
jagortho
Sep 6, 2010 10:11 PM
Edlanta
Sep 8, 2009 12:55 PM
