Check Rear Lights Error when right turn signal is on and brake pedal is pushed
2000 VDP-SC
Has anyone had this issue?
"Check Rear Lights" error message displays when right turn signal is on & the brake pedal is pushed.
This is happening with my jag, intermittently but regularly.
Thanks,
Terri
Fairfax, VA
Thanks,
Terri
Fairfax, VA
This sounds similar to a problem that used to occur back about 25 years when I had an earth problem in the rear light unit of a car I had. You sometimes follow a car and when he has his indicator flashing and then brakes at the same time you notice the brake light appears to slightly flash as well, I would certainly check the earth connection behind the rear light cluster, you may be able to fit a secondary earth link to supplement the original if you cannot get to it.
Tony K
Mar 26, 2024 01:53 PM
