Code Questions 2004 XJ
Old Mar 26, 2018 | 06:43 PM
jds547's Avatar
Default Code Questions 2004 XJ
2004 XJ has a recently installed new Fuel Pump and Air Filter
I am getting the following codes at start-up; PO171, PO174, and PO193. These codes would seem to indicate that the engine is running learn. The engine, however, seems to running ok,
This is confusing. Can someone comment on what might be happening? Thanks,
Old Mar 28, 2018 | 12:35 PM
JagV8's Avatar
PO -> P0 and then you can look up the codes in the free info
It's not running fine, as the codes show, just not so bad that you notice (yet).
There are so many threads about these codes that it's well worth reading some (as well as the workshop manual etc) as they give causes & fixes.
pauleysg
XJ40 ( XJ81 )
Feb 16, 2013 02:47 PM
stkxjrtech
Jul 9, 2010 12:20 AM
jonbugh
Jun 17, 2009 10:19 PM
mosesbotbol
Feb 25, 2009 01:01 PM
CRZYCAT
Feb 3, 2007 11:40 AM
