Coil Codes Help
Old Apr 29, 2020 | 08:08 AM
Ross Von Brobyn's Avatar
Default Coil Codes Help
Hi,
I just wondered if any one else has seen this particular issue or some advice before I take it to a jag specialist.
I have a reoccurring fault, doesn't cause a restricted performance, but will cause an engine light.
The codes:
P0353 Ignition Coil C primary/secondary circuit
P0355 Ignition Coil E primary/secondary circuit
P0358 Ignition Coil H primary/secondary circuit
P1368 Igntion system failure group 2
I replaced the coils, that it pointed towards. Two on one bank and one on the other, which seemed strange. Still the same codes pop back up.
As for the P1368, I can't find mention of any common fuse or relays to each bank as they are all coil on plug.
Any one experienced a similar issue?
Car is a XJR 2005.
Old Apr 29, 2020 | 08:26 AM
abonano's Avatar
Originally Posted by Ross Von Brobyn
Hi,
The codes:
Car is a XJR 2005.
Check wiring
looneytunes
Jul 5, 2019 02:45 PM
mdp9702
Feb 22, 2014 12:09 PM
Alan E L
Apr 18, 2013 09:01 PM
JcsJag
Apr 7, 2013 03:11 PM
walt_00XKRConv
Dec 14, 2012 12:19 AM
