Coil Spring Conversion - Dashboard Warning Light?
Old Jul 8, 2013 | 04:20 PM
cmotomn's Avatar
Default Coil Spring Conversion - Dashboard Warning Light?
All,
Quick question for the group on replacing air springs with coil springs. I assumed a fault bypass was available for all X350 & X358 models, but the Arnott website states "Instructions to bypass 04-06 Dashboard Warning Light" are included. I called their sales & tech support to verify the bypass was only available for 2004 - 2006 model years, which they confirmed and said there was no bypass available for 2007 to 2009 due to a change made in the vehicle.
Is there any other solution available to eliminate the dashboard warning light on 2007 - 2009 X350 & X358's after the air-to-coil spring conversion is performed?
Old Jul 8, 2013 | 09:29 PM
peddlarbob's Avatar
Originally Posted by cmotomn
All,
"As far as I know"
The later cars 2007 to 2009 did not have air ride suspension on the front only on the rear. The front were spring over coils. This was done I beleive to eliminate the problem being experienced by some owners on the earlier model cars with the "front" air coils.
Old Jul 9, 2013 | 09:42 AM
cmotomn's Avatar
Actually the front-coil with rear-air spring design didn't occur until the new X351 model.
Old Jul 9, 2013 | 12:08 PM
Partick the Cat's Avatar
Air springs front & back here - 2008 (H28***)
JarodL
Mar 7, 2024 01:39 AM
D.K
Dec 10, 2023 02:05 AM
Jpav27
Jul 31, 2022 06:43 AM
EZDriver
Sep 8, 2015 09:25 AM
XFR_Gold
Sep 2, 2015 12:24 PM
