Connect with bluetooth Jaguar
Old May 6, 2015 | 04:11 PM
Cjice521's Avatar
Default Connect with bluetooth Jaguar
All I want to do is play my music from my iPhone 5s. I'm am trying to connect to my car via Bluetooth or pairing whatever it's called but it just won't work, I typed in the code idk how many times and press the phone button and it says no phone is connected but jaguar never pops up on my iPhone 5s idk if I am doing something wrong or what
I have a 2004 xj8 X350
Old May 6, 2015 | 08:25 PM
carelm's Avatar
Unfortunately, the iPhone 5s may not be compatible. Jaguar's compatibility list for iPhones only goes to iPhone 4s. I have an iPhone 4 and it connected just fine.
However, if you want the music capability, you will need to install Jaguar's Audio Compatibility Module. It will run about $700 or so, but even the Jaguar service tech I normally deal with doesn't think much of it. You may want to check with some audio shops to see what they can do.
Old May 6, 2015 | 09:55 PM
crackersntea's Avatar
It may not be your phone... You car may be the source of the issue.. Depending on the vehicle type, your vehicle may only be compatible with CERTAIN phones...
Old May 7, 2015 | 08:35 AM
JagV8's Avatar
Or there may be another iOS update that makes it work, if Apple make more.
Old May 8, 2015 | 02:16 AM
veffremov's Avatar
First are you sure you have bluetooth installed in the car? The 2004 cars did not have the phone option standard and even if the phone option was installed it was for a wired Motorola phone.
Then even if you somehow manage to pair the phone with the car it only supports phone calls, no music streaming.
<shameless self promotion>
I have a project here that would address the music streaming part, it would be available mid summer.
https://www.jaguarforums.com/forum/a...ptical-134964/
</shameless self promotion>
Old May 10, 2015 | 12:19 PM
Naso--Lituratus's Avatar
Exclamation
Food for thought. I have been meaning to do this in the Bimmer for quite some time now...
Totally different species.... But this would be mighty cool. Nexus 7 Installed in E46! - Bimmerfest - BMW Forums
Old May 16, 2015 | 04:35 AM
Jagfrenchie's Avatar
As per my researches the bluetooth came only from 2005 models
To convert to bluetooth , you need to upgrade the voice control module located in the boot with higher version and replace the handset in the driver armrest by a bluetooth antenna .
Voice module are quite easy to find on ebay, the main issue is bluetooth antenna.
If someone knows where to find not for 600usd .... I'm interested
Rgds
Thierry
ClassiXtype
Oct 22, 2023 05:29 AM
hafren
Aug 30, 2023 03:42 PM
ControlIssues
Sep 3, 2015 07:38 PM
FLStype
Aug 30, 2015 07:27 PM
EastFalk
Aug 29, 2015 08:22 PM
