Correct jack points?
Old Apr 7, 2012 | 05:20 PM
MTW's Avatar
MTW
Default Correct jack points?
Wanted to replace the diff. fluid. What are the correct jack points? - I know about the ones after the front wheels and before the rear wheels, but are there any other recommended jack points that could be used? The manual does not talk about others than the ones on the door sill.
Martin
Old Apr 7, 2012 | 07:54 PM
jahummer's Avatar
Isn't the differential "sealed for life" with synthetic fluid?
Old Apr 7, 2012 | 09:09 PM
donch61's Avatar
Here's the jack points...
Old Apr 7, 2012 | 09:19 PM
MTW's Avatar
MTW
Thanks!! donch61.
Correct sealed for life just like the transmission - it will me a short life
Old Apr 8, 2012 | 11:47 AM
donch61's Avatar
I replaced the diff fluid in mine. It needed it! Search on "Differential (Rear Axle) fluid change" with my ID and you will find my procedure/tools on the change. Its simple with the right tools.
Old Apr 9, 2012 | 08:53 AM
MTW's Avatar
MTW
Thanks donch61. I read your tread some time back - very helpful - I appreciate it - I would have been very puzzled about actually using the ratchet without a key if I had not seen you tread. I needed a tiny hose on a 100ml syringe for the bottom of the diff - i had a tiny plastic pipe at the end so I thoroughly could vacuum the bottom of the diff - it was thick and black the crap that came up from down there - Wow (I guess you dont notice it the same way when you have a drain plug). I had a little shavings on the magnetic plug - but no concern. I was able to get approx. the full volume (1.38Qts) into it again so I most have gotten most out - no wonder I got a little obsessed.
Martin
bamforp
Aug 14, 2024 05:36 PM
1100me
Jul 24, 2023 06:10 PM
Doug
Feb 27, 2019 01:31 AM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
Bones
Sep 8, 2015 08:34 PM
