The correct way to get an air suspension fault...
Old Jul 10, 2014 | 05:05 PM
H20boy's Avatar
Default The correct way to get an air suspension fault...
I didn't have to test any lines or individual shocks themselves...that's the good news. Now, I need to buy a replacement Arnott...unless someone has a used, good OEM air shock. Anyone? PM me
Old Jul 11, 2014 | 02:59 PM
Xag's Avatar
Xag
Matt,
That's a hole in one! Sorry, couldn't resist. ;-)
Hope you find a replacement soon. One of mine needs replacing too but it's a slow leaker.
Guus
Old Jul 11, 2014 | 03:39 PM
Don B's Avatar
Hi H20boy,
Have you confirmed that the air spring bladder is also punctured? The photo shows a hole in the corrugated gaiter, but that's just a dust cover. The air bladder is inside, and if I'm not mistaken, much of it is covered by that metal sleeve. If you can identify a hole in the air bladder, I and others here would be grateful for some closeup photos showing the damage.
Thanks!
Don
Old Jul 11, 2014 | 04:03 PM
Fraser Mitchell's Avatar
The pressure in the air spring is so high, that if the air bladder gives way, the power of the exhausting air invariably shatters the gaiter.
Old Jul 11, 2014 | 11:22 PM
lcmjaguar's Avatar
Hi H20boy,
Just curious, another shock with a blown hole, does that happen after going over some heavy road bumps or does it just happy at any time? Sure would be nice to have it taken apart so we all can see how it is constructed inside.
Old Jul 13, 2014 | 01:14 AM
H20boy's Avatar
A couple days prior, I hit a teeth-rattling pothole, and prior to that, a transition of new pavement in a construction zone that was very abrupt...enough that I 'puckered' after doing each...just waiting for my nose to dive. As Fraser theorized, I think the bladder leaked inside the gaiter and eventually blew out the front as the pic shows. That explains why the car could be driven for a couple trips after before this happened. I'll see if I can get a pic behind the gaiter when I pull it from the car this week upon the new Arnott arrival.
Old Jul 13, 2014 | 02:43 AM
Xag's Avatar
Xag
Thanks Matt,
That would be very interesting to see.
Guus
Mugatu
22
Jun 23, 2020 01:50 PM
philwarner
Sep 3, 2015 10:14 PM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
