Cruise control not available
Old Jul 24, 2015 | 06:36 AM
ryejag's Avatar
Default Cruise control not available
On my 2004 XJR, I have had intermittent issues with ABS warning lights but that is not on right now. I am only getting Cruise control not available after driving a short distance and then it remains on. Any clues?
RyeJag
Old Jul 24, 2015 | 07:37 AM
carelm's Avatar
RyeJag
I would check out your battery. When it starts going south, it causes all sorts of fault messages. I had the dreaded cruise not available about a year ago and replaced my battery. That solved it.
Old Jul 24, 2015 | 09:32 AM
Marque's Avatar
Yeah, ^^^ what he said^^^. I'd look into that 1st...
Old Jul 24, 2015 | 10:10 AM
trosty's Avatar
+1 on the battery.
Secondly maybe a ABS Sensor clean. A 5 minute job on each wheel. Unclip the sensor, clean with rag, replace. I had an ABS/DCS/Cruise issue rectified by cleaning the Sensors.
Old Aug 2, 2015 | 03:18 PM
XJRTrooper's Avatar
I've had the same problem for the past 2 years. I asked the forum, but all suggestions have not worked. I cleaned and tightened grounds, replaced the brake pedal switch, cleaned wheel sensors, etc. It's funny, but sometimes in very hot weather, the system works! I have not gone to the Jag dealer to have the codes read yet. I am bound and determined to diagnose and fix this myself! Any more helpful input is welcome. Please let me know if and how your resolve your issue. By the way, my battery was brand new when this began 2 years ago.
Old Aug 26, 2015 | 09:46 PM
Gungi's Avatar
I had the same problem, cruise not available battery seemed ok so I ruled that out until one afternoon cleaning car with doors open etc. after a few hours not enough battery to start. Went and got a new one and all the cruise problems GONE!!
Old Aug 26, 2015 | 09:53 PM
Torrid's Avatar
Yep, same happened to me too. I've never met a car more finicky about a battery than a modern Jaguar. Our S-Type radio wouldn't turn on even though the car started fine when the battery started to wear out.
MrWhite
19
Jun 14, 2022 07:49 PM
MrWhite
Oct 1, 2015 01:43 AM
leep123
Sep 30, 2015 03:41 PM
Camnelson324
Sep 27, 2015 08:48 AM
zdrapec
Sep 25, 2015 05:49 AM
