Dealership Costs
I fixed the suspension on my own, but am thinking about getting my tranny fluid changed before i write off the transmission altogether. This whole 'sealed for life' nonsense seems to make changing it messier and more of a pain than i care to deal with. Also i want them to check for codes to see if it could be anything more than just low or old fluid. Does anyone know how much they would typically charge for a fluid flush on an 04 XJR. It's got a zf tranny. Also, would they do a supercharger oil change? I believe that is also a 'sealed for life' unit, but that just sounds like it is going to go sooner or later if the oil is never changed. Thanks guys!
There's a link in the FAQ section about this:
https://www.jaguarforums.com/forum/x...ale-faq-44765/
Link to purchase the parts:
The CTSC - ZF Parts
You'll probably need to find an independent shop to do the work. I'm not sure if the dealer will or won't with supplies you purchase. Plus, an independent Jag Shop will likely cost less. I'd just make sure that they have experience with doing the job.
The CTSC - ZF Parts
LilaJagHubby
Oct 6, 2015 02:56 AM
