Differential Bearing Failure
Old Nov 1, 2015 | 01:20 PM
Edwin12020's Avatar
Unhappy Differential Bearing Failure
My 2009 XJ was towed off the highway after filling with smoke yesterday. Pinion bearing in front of the differential failed, and the oil was on the exhaust pipe. Only 50k on the car; is this common???
Old Nov 1, 2015 | 02:01 PM
trosty's Avatar
I would hope not. Haven't heard of that particular issue before, but there's always the first time of when, not if, it was going to happen.
I have a rear diff that leaks out of the shaft /diff mounting box and needs periodically refilling (that I actually got out and done today) but so far have not had any drip onto the exhausts.
Must be lucky I suppose.
Old Nov 1, 2015 | 03:58 PM
Fraser Mitchell's Avatar
Very unusual fault, and I have not seen a post on this previously, but like all parts on a car, the possibility is always there of failure.
Old Nov 2, 2015 | 01:30 PM
carelm's Avatar
Was this covered under warranty? I had to replace the differential on my previous Jag, an S-Type under warranty since it was a Select Edition car. You may also want to check out any TSBs that cover differentials.
Ramon Torrandell
Nov 2, 2015 06:40 PM
bcucharternet
Oct 31, 2015 09:27 PM
Ramon Torrandell
Oct 31, 2015 04:03 PM
bullittandy
Oct 30, 2015 11:57 PM
Pash
General Tech Help
Oct 27, 2015 07:24 PM
