Door locks, locking and unlocking
Old May 12, 2022 | 04:47 PM
mortimerjd's Avatar
Default Door locks, locking and unlocking
I pulled the door cards to repair speakers in both the drivers and passenger doors this weekend. Ever since doing so now my locks randomly block and unlock two to three times every time I use my key fob to either lock or unlock the doors. I also cannot manually unlock or lock the doors using the interior paddles by the handles. I'm fairly certain I inserted the cable correctly. Back into the mechanism when putting the door back together was pretty straightforward. Other than taking the doors apart to look, is there anything I should have done when putting the doors back together?
Old May 12, 2022 | 06:05 PM
meirion1's Avatar
The most likely fault is that a cable is too tight.
Old Feb 27, 2024 | 02:54 PM
coles84jag's Avatar
[QUOTE=meirion1;2524623]The most likely fault is that a cable is too tight.[/
This was my problem thank you.
Aram
Feb 14, 2022 09:40 PM
max224
Dec 26, 2021 04:27 AM
verdugo
May 18, 2021 07:04 PM
Slocs
Jul 28, 2014 05:19 PM
