How to remove connectore from cd changer
I am trying to unplug the small connector at the back of the cd changer unit, it has 3 wires going to it. I dont see any locking tab but it won't move when I tug on it. I don't want to put to much force and break it so hopefully someone can offer some guidance. Thanks and yippee for this great forum.
There should be a tab depressor on the backside of the connector. You might not be able to see it - depress with a small flat blade screw driver.. Or, the depressor tabs might be on each side - you squeeze both in and remove the connector
OK with more light and magnification I could see no lock tabs so with a screwdriver for leverage eased it out of socket. All is well. Thanks
