Dreaded coolant smell....ugh
Old Mar 12, 2014 | 11:51 AM
VinnyT's Avatar
Default Dreaded coolant smell....ugh
I noticed today that I am getting the notorious coolant smell. I did research on here and saw that it can come from a few places. Nipples on tank, seams on tank, coolant lines from tank to engine, t-stat housing and the<cringe>hose behind the block.
I'll check to see if any coolant is leaking from the tank and make my way back. My question is, what is the percentage of the rear coolant lines fail?
Old Mar 12, 2014 | 01:04 PM
Fulton's Avatar
get yourself a coolant leak tester, it's much easier to find a leak with the engine cold and not running. Many auto parts stores will loan you one or Harbor Freight has one for about $80. All coolant hoses will fail eventually.
Old Mar 12, 2014 | 04:23 PM
meirion1's Avatar
Just to be clear Vinny, the,'hose behind the block' is a small hose which leaks into the vee of the engine and the coolant runs to the back of the engine.
My jag is 3.5 l n/a so I can't tell you more detail-members on your side of the pond will know more.
Old Mar 13, 2014 | 07:46 AM
VinnyT's Avatar
Thanks. I'm hoping it isn't that one. It seems to be coming from the front of the car than the rear. I'll take a closer look this weekend.
MrWhite
19
Jun 14, 2022 07:49 PM
X308XJR
May 20, 2019 06:50 PM
vwbusbits
Oct 13, 2015 03:43 AM
dmatthewman
Sep 30, 2015 10:10 AM
