The dreaded Restricted performance!
Was driving on the freeway the other day when car lost power, managed to make it off and park on the side of the road. Car started once and died and it hasn't started since. The codes are P0628 & P0629 (I searched the forum with no luck). I am guessing it's either the fuel pump or the fuel pump control module. Anyone else had this issue? The control module can be had for around $30, the fuel pump quite a bit more.
Thanks, Mark
Thanks, Mark
Hi p0628 = fuel pump a control circuit low p0628 = fuel pump control circuit high so yes problem is fuel pump related check earth points related to fuel pump wold be my first item to check ?
FS[MidAtlantic]: 2002 Jaguar XKR Convertible - Beautiful
stingray71
Jan 7, 2017 03:44 PM
pricebill
Oct 27, 2016 01:20 PM
