driver window
Old Nov 2, 2021 | 01:14 PM
GunnyGil's Avatar
Default driver window
Hey Guys, If I solve this I can drive it for a while before next time to work on it, My driver window is down and I can't get it back up. I can take it to Jaguar or we can attempt to fix it here. I have tried changing the motor I have tried changing the DDCM which causes more problems. I have checked wires I can find nothing. Has anyone encountered this before? It went down for global opening. (I had put it up manually previously). But if I use global close the only thing that moves is the sunroof... it closes half way then reopens.
Old Nov 2, 2021 | 05:36 PM
meirion1's Avatar
Try a reset ie remove battery connections and touch together for 2 mins.
Reconnect to battery.
You will then need to drive every window up to the max and hold switch up for 5 secs
to reset the one touch close.
draganapiazzola
Aug 6, 2016 07:07 PM
JohnBJag
Aug 10, 2014 12:32 AM
emaraszek
Nov 20, 2012 10:07 PM
monz87
Sep 8, 2010 05:34 AM
