Electrical System
Old Oct 27, 2010 | 08:38 AM
test point's Avatar
First thought is that the battery is done for. If you can keep it running stop by an auto parts store for a free test, if not take the battery out and take it in for tests.
Old Oct 27, 2010 | 08:54 AM
MidlifeXJR's Avatar
It is the battery, you are experiencing the documented gremlins of low voltage. If you don't have a charger... get one, take it in to an auto parts store and have the battery tested. They will determine if a charge is all you need or if your battery needs replacing.
Get that taken care of and besides having to reset all your settings, fob, seat memory, radio settings, etc., everything should be back to normal.
Old Oct 27, 2010 | 10:58 AM
JimmyL's Avatar
Default Battery
I have had things like that happen to me due to low battery / bad ground. Chimes going off, TRAC/ASC Unavailable, seat and steering wheel moving. It's really weird. I'd check and clean up the grounds and power posts too.
02jagstype
23
Oct 23, 2022 07:03 PM
mbergen
Oct 23, 2019 10:26 PM
Rablaw1971
Sep 11, 2015 10:24 PM
1100me
Sep 7, 2015 06:26 AM
mcdutch
Sep 4, 2015 03:38 AM
