emergency brake issues
Old Oct 29, 2017 | 10:23 AM
chuckie's Avatar
Default emergency brake issues
replaced brake pads and rotors and emergency brake fails, followed brake seqences then locked up rear wheel disengaged/compressed rear right caliper piston and took fuse out - parking brake at fault with beeping sound when moving - brakes work fine
Old Oct 29, 2017 | 10:29 AM
NBCat's Avatar
It is always helpful if you list the MY and other vehicle details.
Follow the procedure in the Owner's Manual for resetting the handbrake.
Old Oct 29, 2017 | 05:14 PM
chuckie's Avatar
2009 xj8 - tried to reset emergency brake two times and the third time lock up right rear wheel using the owners manual so I proceeded to reset caliper brakes work fine however no emergency brake how do I recalibrate/ or change motor that pulls cables to engage rear calipers
Old Nov 1, 2017 | 12:43 AM
EdBwoy's Avatar
If I remember right, the fault light is on because the EPB motor itself has a sensor as to how far and how much resistance it should feel when engaged. I don't know why only one side would lock up.
Did you perhaps remove and forget to reseat the bung that fastens the brake cable in its bracket? This tan/ off-white thing.
Old Nov 1, 2017 | 12:54 AM
EdBwoy's Avatar
If all checks out, I'd try to engage and disengage the parking brake by bypassing the module and trying to reset inside the car.
This video might be of some help to you:
Remember to reconnect your fuse!
Old Nov 9, 2017 | 08:06 AM
chuckie's Avatar
I have already viewed this video before I brought this emergency brake issue with the forum however my vehicle is a 2009 XJ not a 2005 and could not find this module with proper wire arrangement - is there a way to turnoff /disconnect this repeated bonging sound while driving. Hopefully you have a solution to this dilemma. Thanks in advance to your reply/solution.
Chuckie
JimC64
Sep 22, 2025 02:52 PM
slojotaa
F-Pace (X761) / C-X17
Sep 6, 2017 12:29 PM
Jeff DeVere
Oct 13, 2016 07:00 AM
phreadd
Oct 6, 2016 10:10 AM
modell
Feb 24, 2007 11:24 PM
