Encountered issue changing shock bushings - help
Old Oct 15, 2018 | 06:33 PM
Philbekker's Avatar
Default Encountered issue changing shock bushings - help
i followed a few forum posts with attached photographs to change the upper front shock bushings on my newly acquired XJ8 2003. Jacked both sides up and left a couple of inches clear beneath the tires. When I finally reached the point of removing the 17mm nut on top of the bushing, there was almost like a mini explosion and the nut went flying off ( still have not found it ). It seems the the threaded rod from the shock went back a little.
When I did the other side, I used a socket for the last thread instead of the wrench the whole time. Same story - didnt lose the nut this time ( only because of the socket being there ) but same ‘pop’ of an explosion the the threaded section of the shock has retreated a little bit and Im not sure that its going to protrude enough to allow the nut to be put back on once I get the bushing replaced tomorrow at Napa, who have a press. Will lowering the jack help ? Sorry to be such an amateur !
(Atlanta )
Old Oct 16, 2018 | 03:58 AM
Fraser Mitchell's Avatar
From your description, your car is in the X308 series of XJ saloons, not the later X350 aluminium cars. Might be best to post in the X308 forum.
Old Oct 22, 2018 | 12:42 AM
Philbekker's Avatar
Thanks !
cat hoarder
Jun 14, 2016 06:05 PM
2003XJR
Feb 20, 2013 10:13 AM
disguay
Aug 20, 2012 03:44 PM
SirJag
Jul 2, 2012 04:12 PM
H20boy
General Tech Help
Oct 31, 2010 08:27 PM
