engine oil capacity
Old Apr 9, 2025 | 07:06 PM
Terrific's Avatar
Default engine oil capacity
I'm sure this question has been asked before but I couldn't find a post. The owners manual shows that oil change capacity for my 2005 VDP 4.2L to be 5 .75 US gts.. with filter. change.. It always takes me almost 7 qts. to fill to the max mark on the dipstick. Anyone??
Old Apr 10, 2025 | 06:57 AM
redrover41's Avatar
~7 quarts is accurate. See below:
"The Jaguar 4.2L naturally aspirated (NA) V8 engine typically requires around 6.5 to 7.4 quarts (6.0 to 6.9 liters) of oil with a filter change".
0W-30 is the preferred weight.
Old Apr 10, 2025 | 02:58 PM
Pete M's Avatar
The recommended oil is 5W-30 not 0W-30.
Pete M
Old Apr 10, 2025 | 03:01 PM
redrover41's Avatar
Default My bad, folks!
5W-30 IS the recommended oil.
I have had my wife's Jeep Cherokee on my mind the last couple of weeks, yes, and oil cooler problem. Duh.
rsa
Old Apr 11, 2025 | 09:41 AM
DaveAllen's Avatar
My owners manual (JJM 18 02 21 701) for 2007 XJ8 says 7.4 quarts, including oil filter. Same for N/A and S/C
SAE viscosity rating
For climates ranging from –30°C (–22°F)
and +50°C (+122°F), the following oil
viscosities may be used:
0W–30
5W–30 (preferred)
0W–40
5W–40
HTH, Dave
Old Apr 14, 2025 | 10:45 AM
Rickkk's Avatar
My 2005 Jaguar XJ8L 4.2L V8 engine takes (more or less) 7.5 quarts of 5W-30 engine oil.
ArtyH
Aug 20, 2016 11:41 AM
mick99
Jul 23, 2013 01:48 PM
Lannyl81
Oct 29, 2012 12:59 PM
vance580
Jul 25, 2010 10:08 AM
mosesbotbol
Apr 29, 2010 01:01 PM
