Engine/Supercharger Cover
Old Jun 28, 2013 | 06:08 PM
PigletJohn's Avatar
Thumbs up Engine/Supercharger Cover
my first post, apologies if this has already been covered, but I searched and couldn't see it.
I like to see a clean, neat engine when I open the bonnet. I have a 2005 Super 8 (I believe the XJR engine is the same) and there is just a slab of black plastic. I expect it is there to muffle sound or keep the rain off.
Can I just remove this cover and give the top of the engine a clean and polish, or is there more to it than that? Will it matter if I leave it off?
TIA
Old Jun 28, 2013 | 06:59 PM
Welcome to the forum PigletJohn,
Most engines are covered with plastic mouldings nowadays. Designers do it give a 'cleaner' look.
They also play a part in airflow and cooling but may not be critical. Members with the same model will be able to advise.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST section and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Jun 29, 2013 | 12:00 AM
34by151's Avatar
The engine cover reduces intake temps well not the cover but the heat shield under it.
I covered this in stage 1 intake tubes thread along with test results
34by151
Old Jun 29, 2013 | 05:43 AM
PigletJohn's Avatar
thanks, the heat soak thread is interesting. I was looking under the bonnet of an X308 super recently, and his engine looks much prettier and more purposeful than my X350 except that it opens the wrong way.
I may take the cover off just to see how it looks, but if the intake air is going to get needlessly hot I suppose it had better stay.
Will do an intro later.
Last edited by PigletJohn; Jun 30, 2013 at 05:55 AM. Reason: to correct model number
SeanU
Mar 17, 2021 10:38 PM
indi4ever
Oct 8, 2015 10:23 AM
salP3082
Sep 25, 2015 05:07 PM
Philurusso
Sep 20, 2015 07:02 AM
jaggermang
Sep 8, 2015 07:07 PM
