Exhaust Flexi Joint Blowing & Inlet Port Deviation Diaphrams required
Old Oct 23, 2015 | 03:52 AM
Redtop's Avatar
Default Exhaust Flexi Joint Blowing & Inlet Port Deviation Diaphrams required
My 2009 XJ (2.7TD) was checked at an authorized dealer after having repeated "Restricted performance" warnings. The dealer said that the Nearside Exhaust Flexi Joint was Blowing (new Flexi Pipes required) and Inlet Port Deviation Diaphrams were required. Estimate for Parts was Euro €722, Labour was €460 + Tax = €1,341. What scares me apart from the Price is that they said that they would investigate if the problem continues after doing this work, which suggests that more work may be required. I was thinking of showing it to an Indie but was interested in your thoughts & feedback. Thanks.
Old Oct 23, 2015 | 04:55 AM
Redtop's Avatar
I should note that this is the older model XJ which finished in 2009. I think it's an X358, but not 100% sure. It's not the current model which started in the same year (2009).
Old Oct 24, 2015 | 04:57 AM
Fraser Mitchell's Avatar
Better to post your thread in the X350 forum where you'll get a better response.
There is a Jaguar 'kit' for these exhaust pipes at the point where they fail, so you don't have to buy the full shebang. I don't know the price (your price doesn't have a breakdown), but I suspect the dealer has quoted for the kit as the price includes the inlet port parts.
Are both sides cracked and blowing ?
Old Oct 25, 2015 | 03:49 PM
Redtop's Avatar
Thanks. They said that the Nearside one was blowing. They quoted for 2 x Downpipes at €266 each, 3 x Clamps averaging €23 each, a Gasket €13, a Stud €3 and a Manifold Actuator €41. That's excluding Labour & Taxes.
Old Oct 25, 2015 | 05:15 PM
I'm sure I've replied to this somewhere ! Was it on the other Jaguar forum ?
Old Oct 25, 2015 | 07:54 PM
Usually if one side goes, then the other probably isn't far away!
Makes sense to do both at once but totally up to you of course, looks like they're quoting to do both sides and seems a reasonable price.
Not so long ago Jaguar would've told you both cats needed replacing at around £2000+
If it's blowing as they say, you'll be smelling diesel fumes in the cabin, especially when stationary.
H.Jones
Feb 27, 2016 04:41 AM
tassiejag
Jan 16, 2016 01:55 AM
simongulliver
Oct 21, 2015 05:03 AM
JagsDaughter
Oct 18, 2015 11:38 AM
hstovall1
Oct 17, 2015 09:32 AM
