False alarm
Old Sep 11, 2009 | 09:17 AM
alpine,jag's Avatar
Default False alarm
Forr the last 4 nights in a row the alarm on my 04 xjr has been going off for no reason Any idea of wats wrong
Old Sep 11, 2009 | 05:25 PM
hlgeorge's Avatar
Could be a weak battery. Also do a hard boot for all the computers and see if that works.
Old Sep 11, 2009 | 08:32 PM
mohrd's Avatar
How do you know it's for no reason? Maybe it's just a really stupid car thief that thinks he'll have better luck the next night.
Old Oct 29, 2009 | 03:15 PM
ColinP's Avatar
I have a similar problem. How do you do hard boot for all the computers?
Old Oct 29, 2009 | 05:12 PM
H20boy's Avatar
remove negative cable from battery, touch positive terminal for a sec. clears all memory and capacitors. thats the hard one.
Old Oct 30, 2009 | 03:51 PM
ColinP's Avatar
I gave it a try. The problem happens 2-3 times a week so I'll have to wait and see if it does the trick! FYI I have a 2004 XJ8 and discovered that the problem is being caused by a false "Bonnet Open" alarm.
Old Oct 31, 2009 | 05:19 PM
hlgeorge's Avatar
I get the "Bonnet Open" on my car every so often. I had the dealer look at it and they said everything checks out fine. When it happens I just open and re-close the bonnet with a hard slam. It doesn't re-occur until the bonnet is opened again.
Old Nov 2, 2009 | 03:24 PM
ColinP's Avatar
Well that didn't work! The alarm went off again over the weekend!
I know its being caused by a false "bonnet open". I have tried opening the bonnet and slamming it shut but it still occurs. Anyone have any ideas???
Old Nov 2, 2009 | 03:33 PM
ColinP's Avatar
My first thought was a bad switch on the bonnet (hood) so I tried opening it and slamming it shut but it doesn't clear the alarm display and I often get a "Bonnet Open" alarm while driving. If I could figure out where the switch was I'd try replacing it but I haven't been able to find it yet. It shouldn't be that difficult to find...anyone know where its located? Its a 2004 XJ8 VDP by the way.
Old Nov 3, 2009 | 12:52 PM
alpine,jag's Avatar
Default No Mo ALARMS
I got it I remembered that i took my front bumper off to install a bigger innercooler. After reinstalling the front bumper i noticed the hood didnt line up. so i addjusted the hood. This cause my open bonnet light to come on from time to time after talking to a good reputable jag mechanic i found out that the bonnet light is wired with the alarm system. long story short I ajusted the bonnet switch (On the bottom part of the hood latch) and havent had the alarm go off for two nights
Old Nov 10, 2009 | 02:03 PM
ColinP's Avatar
Found and replaced the "Under bonnet security switch" and so far things are looking good. Hopefully the problem is now resolved!
k-man
Oct 5, 2015 08:09 AM
redxk8
Oct 4, 2015 08:28 AM
baskervillema
Oct 1, 2015 06:43 PM
Bigvettefreak
Sep 28, 2015 03:03 AM
