Fan is running
I am still new to my XJ8 and it confounds me every time I park it, after a drive, that the radiator fan goes on and stays on for 2-3min. Is this normal for the XJ8? I have never encountered this in other cars.
Thank you in advance
Well temperature spiked today all the way in the red just to get normal 30sec later - so correct it is a temperature sensor - goes to the dealer tomorrow. Just had the car for one day
hope it will get better! at least it is a minor thing. Thanks
Would change your thermostat quickly, that one is known to stick in different positions (could be in open or closed state), it is very common, and I had it myself also.
Here was just recently a case again:
https://www.jaguarforums.com/forum/s...ad.php?t=34360
The coolant sesnors on the 4.2s have a large failure rate. Early 2004 sensors, had high failure rates. Make sure you get the correct one as they changed in MYs.
stevetech is right, I am a bit to used from other forums that there is a split between the X35x and X30x versions.
No one reads the Service Manual?!?!
This is downloaded from Jaguar’s TOPIX on my 2006 XJ8 (X350)
Cooling Fan
A single, variable speed cooling fan motor is attached to a fan shroud located behind the radiator. The speed is determined by the Engine Coolant Temperature (ECT) and the air conditioning pressure and transmission oil temperature.
Under hot operating conditions, the fan may continue to operate for four minutes after the engine has been switched off.
Cooling Fan
Cooling Fan
Cooling Fan
The combination of an aluminum engine and a dash Temp Gauge that is a glorified idiot light (it has zero range above mid-point and will NOT alert the driver to climbing engine temps, until: PING! Snap to the "H" and when it does so, you are ALREADY in an overheated condition. What I try to do is determine what "normal" operation is across multiple scenarios, and only become concerned when something changes. I suspect this new Jaguar owner is trying to determine what "normal" is for their situation.
This combination creates almost a perfect storm, where several minutes of indecision, or a misunderstanding that you can drive the car gently/slowly for 10 or more minutes spell disaster. It is a horrible setup, forced on Jaguar by Ford -as a way to save $2.11 cost per vehicle. Okay I made that up, but it was a terrible decision, whoever was involved. Bottom line, the OP just got the car, wants it to work as designed and came here to ask the question. Good call and a good way to get smart!
Change the entire thermostat housing, they fail and come apart internally, blocking coolant flow. I had the same situation on my X358 when I bought it. The housing comes with the thermostat and temp sensor, all in one unit.
Dave
Dave
If your shopping the thermostat housing, I just picked one up from Harper Jaguar for $125.83 - best price I could find currently. Most want 150 plus. Part number AJ811793.
I'm about to go ape on hoses, Serpentine belt, tensioner, idler pulley. All wear items and I'm showing 109k miles. Still deciding on water pump. I may leave it for now.
XJ8JR
17
Sep 17, 2024 11:07 PM
