foam pads on engine under tray
Old Mar 4, 2016 | 05:16 PM
JtRuth's Avatar
Cool foam pads on engine under tray
Does anyone know just what the two black plastic wrapped foam pads do that are attached to the under engine tray(belly pan)? Also, can you buy replacements and where? On the other hand it could just be a big waste of time and money. But I do try to keep my Jag like it came from the factory. Oh, yea. This is a 2005 VP.....Thanks
Old Mar 7, 2016 | 05:52 AM
rayalbers's Avatar
My idependent mechanic called them a diaper. Said they are there to sop up any tiny oil seepage. In my case, another mechanic (the one I don't use any more) had failed to tighten the oil filter properly - I almost lost the engine due to massive oil leak - and the "diaper" was saturated. My mechanic found that you can't get replacements just for the pads - have to buy the whole tray. About $360, as I recall. Only good news out of that is that I told the other mechanic I felt he was liable for the cost of the tray, and he did pay.
Ray
Old Mar 7, 2016 | 01:09 PM
rosskuhns's Avatar
I removed mine, per one of the jag techs here who said, IIRC, they tend to hold in water too and make a bit of surface rust where they touch, so they take them off. Supposedly to reduce noise, but I've noticed no difference and he said the same.
Old Mar 7, 2016 | 02:20 PM
Torrid's Avatar
Same here, I removed the pads but retained the cover. It's what hid my gearbox leak for awhile. I have considered just leaving the cover off as it seems like the panel can flop around too much without the padding.
Old Mar 7, 2016 | 07:53 PM
jmbpharris's Avatar
Default Foam Pad on Engine Tray
I assumed that the pads were for sound insulation since they appeared to have been completely sealed. Thus I would not have expected them absorb oil, etc. The plastic on our 2004 VDP had split over time - I guess from age and heat. When I had the tray off the car for an oil change, I removed the old plastic, cleaned the foam pads, replaced the covers with plastic from a heavy trash bag and sealed the seams with silicone. I used rubber washers on the posts that secure the pads to the tray. The pads look like new although I am not sure of the benefits, but I try to keep the car original as possible.
XJeej
Mar 18, 2016 06:06 AM
DanielEllensjag
Feb 21, 2016 06:58 PM
Kewpie
Feb 19, 2016 04:12 PM
Isaiah8190
Feb 18, 2016 03:58 PM
Clutch9801
Feb 16, 2016 08:56 AM
