Fog Lamp removal / replacement
Old Aug 29, 2013 | 05:50 PM
Dudeman44's Avatar
Default Fog Lamp removal / replacement
On my 2004 XJ8, I've got a dead fog lamp on the right side. I popped the hood ( bonnet ) to see how hard it is to remove/replace and, wow, I'm totally lost. I don't see any simple or obvious method for removal. Does anyone know of an exploded view or procedure or YouTube video on this? I hate to take it to a mechanic since I prefer doing my own stuff. Same for the headlight, if it ever goes out, I can't see a way to get that out either. This is normally so simple on other cars I've owned.
Old Aug 29, 2013 | 06:27 PM
Here's the JTIS procedure for Front Fog Lamp Removal:
It looks ( perhaps deceptively ) straightforward but then the same can be said about many Jaguar removal procedures which turn out to be anything but simple!
Attached Thumbnails Fog Lamp removal / replacement-x350-fog-lamp.jpg
Old Aug 30, 2013 | 09:49 AM
Dudeman44's Avatar
Thanks much for taking the time to copy this into the post, I'll give it a try this weekend!
Old Aug 30, 2013 | 03:57 PM
banjobill's Avatar
Dudeman44,
I know its hard to believe, but it really is that simple? the cover will be best removed by pressing the top of the cover down and out, you may need a blunt thin tool the help press the tang down to avoid damage.
Two screws and the lamp is out.
Good luck.
Old Aug 30, 2013 | 11:25 PM
psg's Avatar
psg
Not much of a fog light 'anti-theft' cover is it.
Old Aug 31, 2013 | 09:30 AM
MarrtyJ's Avatar
As for the headlight, it is just a bulb you replace from behind the housing. Unless the lens is broken/cracked, you only replace the individual bulb. Simple twist and unlock procedure.
Cheers.
Old Aug 31, 2013 | 11:11 AM
Dudeman44's Avatar
Yes, as it turns out I was able to get to it from behind and it was a fairly simple R&R. Thanks all for the help.
JarodL
Mar 7, 2024 01:39 AM
davidladewig
Sep 3, 2015 06:32 PM
Dallas XK8
Sep 3, 2015 12:17 PM
XJsc-guy
Sep 2, 2015 11:43 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
