Fog Light for XJ?
Old Apr 3, 2015 | 04:27 AM
2intense's Avatar
Default Fog Light for XJ?
I just bought a 2004 XJR and noticed the left (driver side) fog light lens is shattered/broken. Light still comes on but I want to replace it. Two questions:
1) where is the best place to buy a replacement fog light (online)?
2) how do I remove the fog light? How do I access the mounting screws etc? Is there a video or a link someone can share?
Old Apr 3, 2015 | 11:40 AM
Muddybear's Avatar
For a new housing you could try Parts Geek. I pretty sure its less than the dealer.
04 2004 Jaguar XJ8 Fog Light - Body Electrical - ****, Genuine, Philips, Wagner, Front, Front Left, Front Right - PartsGeek
And if you want to upgrade the light output, upgrade to HID bulbs.
I just installed these the other day, H3C: Morimoto Elite HID System - HID Systems
It makes a huge difference. My fog lights now put out more light than the HID low beams. The low beam may not be as bright because they have dimmed over time, so I plan to upgrade the low beams next with quality new D1S bulbs and change out the lens with a clear lens. I would have got a clear lens for my fog lights but couldn't find one 2".
Old Apr 3, 2015 | 11:43 AM
2intense's Avatar
Thanks, is it possible to replace a broken lens our do I need to replace the whole housing?
How do I access the fasteners to remove the housing?
Old Apr 3, 2015 | 01:04 PM
roviw's Avatar
I fitted a replacement foglight ages ago and from memory I think all I did was to unclip the plastic piece next to the foglight, this exposed a fixing screw, I undid that and then as I pulled the light forward and sideways it came unhooked from the other end. There was just an electric plug to disconnect. Then fitting the replacement ( about £45 from ebay ) was the reverse.
Old Apr 4, 2015 | 03:25 PM
Woodford Jag's Avatar
2intense,
I have a used left side fog lamp from my 05 XJR I will sell you. PM me if interested.
Woodford Jag
Jpav27
Jul 31, 2022 06:43 AM
redrover41
23
Sep 25, 2015 01:33 PM
motorhead69
Sep 9, 2015 10:04 AM
avern1
Sep 6, 2015 04:22 PM
XCrossWindsX
Sep 5, 2015 10:58 PM
