Ford Fuel Rail Pressure Sensor Part Number?
Old Jun 11, 2024 | 08:57 AM
Capitalman's Avatar
Default Ford Fuel Rail Pressure Sensor Part Number?
Hello All:
I was getting a P0193 code (Fuel Rail Pressure Sensor A Circuit High) and took a chance and bought an aftermarket sensor, not wise but $ has been tight. No problems for about a month but now getting the same code and showing 69 PSI on the code reader. There are many threads stating a Ford part may work. Does anyone have the Ford Part # that will work for my 2008 XJ8 Vanden Plas 4.2 naturally aspirated engine?
Any help would be greatly appreciated. Thanks.
Old Jun 13, 2024 | 05:20 PM
meirion1's Avatar
Does the replacement sensor look the same as the original?
Looks like it could be made in China?
https://www.aliexpress.com/w/wholesa....best.search.0
Old Jun 14, 2024 | 06:02 AM
Capitalman's Avatar
It was identical to the original. I bit the bullet and went to the Dealer to get one and put this problem to rest. Thanks for the response.
Old Jun 14, 2024 | 05:05 PM
meirion1's Avatar
Ok Is it the black box type or the chrome 'nut' type?
Old Jun 15, 2024 | 12:11 PM
Capitalman's Avatar
Black Box. Picked it up from the Dealer and installed it this morning. If there are any issues down the road I will respond to the forum.
Old Jun 15, 2024 | 07:52 PM
meirion1's Avatar
The used black box type are known for cracked spigots
mikesbaron
Feb 8, 2024 03:52 PM
Pancho Deez
Aug 14, 2023 06:37 PM
sdred
Apr 25, 2021 04:13 PM
Cafcpete
Sep 2, 2019 04:20 AM
mhannaoui
Nov 18, 2018 11:16 PM
