Front crankshaft oil seal replacement
Are their any tricks to replacing the front crankshaft oil seal on a 2005 Jaguar XJR to avoid dismantling a lot of "stuff" in front of the engine?
The transmission is out so I can tilt the engine rear down some what.
I do not want to take the radiator out etc. Would there be any other source of an oil leak on the front of the engine?
jackra_1 (01-20-2020)
Yes. That would not be too bad.
I have read where it can be difficult getting the pulley off.
The build up of oily dirt in this area has happened over 15 years. I see no evidence of a bad leak so far.
My crankshaft pulley/damper separated and damaged the front cover. See my post. https://www.jaguarforums.com/forum/x...advice-225523/
Good job on your part and a very useful post, for me at least.
Nos_Monkeys
12-29-2013 05:37 AM
